12-05-2019 08:56 AM
Hi I am new in camera link. I try to communicate via camera link under labview FPGA with module NI 1483. I can't find example with 4 tap 16 bits. On my test I always have 160*512 pixels. Does someone can help me with example ?
Ludo
02-20-2020 11:15 AM
I am also struggling with a similar problem. Do you have a solution?
02-20-2020 11:29 AM
What version of Labview are you using?
I am using NI 1477 in camera link full in 8xU8 configuration.
What acquisition example are you trying to use?
02-20-2020 12:16 PM
I am using LABview 2019 with a PXI and a flexRIO FPGA+NI1483 as frame grabber. The camera I am using is from the same manufacturer as LUDO.
The acquisition example I am using as base is Hardware Input and Output > FlexRIO > IO MOdules > NI 1483 > 1 Tap 10-Bit Camera with Frame Trigger and Threshold.
I got some success an adapting a 4Tap8Bit code and the further concatenating the bytes into a a word. My pixel intensities are off though.
02-21-2020 08:44 AM
Hi, this is what I do for return data from FPGA
Then for read
Ludo
02-21-2020 05:18 PM
Hi Ludo,
The 1483 and the 1477 should be very similar.
You should be using the acquisition VI from NI to my opinion.
Camera link acquisition VIs are in path:
"C:\Program Files (x86)\National Instruments\LabVIEW 2018\vi.lib\visionFPGA\Basics\Camera Link Acquisition\CL Acquisition"
The VI that you could use is "IMAQ FPGA Camera Link 1 Tap 16-Bit"
Can you setup your camera to 1 Tap acquisition? NI processing VIs can process only single Tap for 16Bit.
03-16-2020 12:33 PM
I am still facing this problem, even if I am using an IMAQ based code. My architecture is simple a FlexRIO reads the cmera link and sends the data to my LabVIEW-RT. My current problem is, I am reading the pixels with the wrong intensity if compared with the measures done by the standard camera system. I am sending also screenshots of my code, the first image refers to the FPGA code and the second one to the LabVIEW-RT.
04-01-2020 04:47 PM
Ludo,
Is this code working? Due to iamge size, I can't see the snapshot from your code well.
04-02-2020 09:42 AM
Hi, yes the code is working. Change your web browser for see jpeg
04-02-2020 10:52 AM
Hi LUDO,
If your code is working. THen maybe it is only issue of bit shift to get the intensity correct.
Is your camera output is 16bit or less.
