I have following problem:
I'm using Duncantech MS-3100 camera connecteted to PC via IMAQ PCI 1428 frame grabber card.
The problem is with original camera control software called DtControl which is not work. I receive following message: "No Frame Grabber Link Found".
But when I look in NI MAX under NI IMAQ devices I can see: img0 : IMAQ PCI-1428 (s/n: 0x0116F741) and that I can find Channel 0: cohu 7700cl not Duncan technologies MS3100 rgb.
And when I import the Duncan technologies MS3100 rgb-1428.icd.It showed error"Error OxBFFF800B,the session you reguested failed to execute,check that the user dll on the system".
I'm using windows 2000, under device manager I can see under National Instruments IMAQ Interfaces: IMAQ PCI-1428 which is according to device manager "working properly".I have used win xp for try,but the result is the same to win2000.
I was installed NI IMAQ v 3.1
Thank's for any help.
huqian
