Machine Vision
measure diameter (tickhness) from binairy picture
What do you mean by reversed Danielsson function?  You can probably get what you want either using math or inverting the image before using the function.
Your skeleton function might work better after applying Erode a few times to get rid of the bumps.
Bruce
Bruce Ammons
Ammons Engineering
Message 41 of 64
(2,096 Views)
Yes apply a preprocessing like erode before you apply skeleton.
Message 42 of 64
(2,082 Views)
But the image will not be the same as the picture anymore?
The vains get bigger than they are, can I solve that?
By inversed daniel I mean that it starts at the middle of the the vain and works his way out,
is that possible?
Message 43 of 64
(2,077 Views)
is that possible?
First why are you going for a skeleton when you are able to do it with detect circles?
Message 44 of 64
(2,075 Views)
Circle detection doesn't fit the demands, it draws circles where ever it can,
but I need to know the diameter at every point so I can make a table how
many procent falls in a certainly range. (yes the demands have changed)
Message 45 of 64
(2,074 Views)
Even If the veins become bigger you can always equate it to the original size right? The size is always going to be proportional isnt it? Correct me if otherwise.
Message 46 of 64
(2,071 Views)
I think so 🙂
Message 47 of 64
(2,070 Views)
Chantal wrote:
I think so 🙂
So should work...?:smileyvery-happy:
Message 48 of 64
(2,069 Views)
There a lot of noise into my pictures, so I first have to solve that, because
it also makes the noise a bit bigger
Message 49 of 64
(2,067 Views)
Can you post an ORIGINAL image. Did you try applying a proper threshold and then apply remove small particles?
Message 50 of 64
(2,066 Views)
