Machine Vision
measure diameter (tickhness) from binairy picture
Message 11 of 64
(3,342 Views)
Message 12 of 64
(3,343 Views)
Is this a special plug-in?
or is goes this with the basic labview programming
and vision software?
Message 13 of 64
(3,339 Views)
VDM
Message 14 of 64
(3,337 Views)
Thanks, If I get stuck on some point I will post again 🙂
thank you for the help, I think you gave me some usefull things 🙂
Message 15 of 64
(3,329 Views)
Yup and do update...:smileywink:
Message 16 of 64
(3,324 Views)
I would consider using IMAQ Distance or IMAQ Danielsson (same palette as Find Circle).  Both do essentially the same thing - they give the binary pixels values equal to their distance from the edge of the particle.  For example, all the pixels on the outer edge will be 1.  All the pixels in the next layer will be 2.  It continues in until all the pixels are given a value.  If you then use IMAQ Quantify to find out the largest pixel value in the image, you will know the radius of the widest part in pixels.  It will probably give you the same accuracy as Find Circle, but would be much faster and easier.
Bruce
Bruce Ammons
Ammons Engineering
Message 17 of 64
(3,305 Views)
I ran a quick test, and it appears to work pretty well.  The only problem I see with this method (which is also present in the Find Circle method) is that the largest diameters will be measured where the veins branch.  There is one spot in the center of the image that has several branches coming together that will measure much larger than the diameter of any vein.
I don't see an easy way to ignore the branch areas at the moment.
Bruce
Bruce Ammons
Ammons Engineering
Message 18 of 64
(3,303 Views)
This code filters out the big circles that form branches.
Message 19 of 64
(3,283 Views)
Today I work futher on this problem, and I will look what works best for me 🙂
Working with the circels gives a quite good image about the thickness of the nerves,
only I need to program it that the user can see how thick everythgin is etc. 🙂
and KevinC I use Labview 8.2 so I can't open it 🙂 Hope you can save it as an older
version so I can see what you have done! thanks 🙂
Message 20 of 64
(3,250 Views)
