Machine Vision
measure diameter (tickhness) from binairy picture
I'm trying to measure the thickness of some vains in a picture, first I made sure that the picture only excist of 2 colors
one for the vains and one for the background, now I'm trying to make a program which measures
the diameter (don't know how to spell it in englisch) of the vains, also the thickness.
Does anyone have an idea?
thanks!
See tag for a picture
Message 1 of 64
(6,796 Views)
Using edge detection you can do this
Message 2 of 64
(6,788 Views)
Yes, I know that, but it has to measure it without a user doing anything.
It has to recognize the vains and than measure te biggest diameter and the smallest.
Do you also have ideas for that?
Message 3 of 64
(6,786 Views)
Ok lemme try..
Message 4 of 64
(6,781 Views)
Oke, I'll see if you can do it, i've tryed a lot of things, so i hope you can give me new ideas how to
solve this problem! 🙂
Message 5 of 64
(6,762 Views)
Circle detection returns this. Can something be deduced from this?
Message 6 of 64
(6,760 Views)
I'll have to try, is that a normal example?
Message 7 of 64
(6,759 Views)
Do you mean a normal practice? I dont think so. But the object being so irregular and the result clearly shows the bigger diametermeans bigger nerves and vice versa give it a try..
Message 8 of 64
(6,757 Views)
I can't find it, but if it's possible to klik on each item and see how big it is,
I can work something out, than it will be great 🙂
Could you please add the program you used?
Thanks!
Message 9 of 64
(6,757 Views)
Hmm... still can't find it, where must I look to get the function circle detection? 🙂
Message 10 of 64
(6,749 Views)
