12-01-2007 01:25 PM
12-02-2007 03:42 PM
Hi there,
Is it possible for you to attach a picture from the camera with the laser dot in?
I suspect one of the best ways to do what you need to is to do a thresold on the image, and then use a particle detection algorithm. (The Vision evelopment Module has all of these functions)
A picture would help me get a better idea of the way forward. What software do you have available?
Adam B
12-03-2007 11:05 AM
Hello, is a pictures, that we get from the camera. We need the coordinates of the middlepoint of the spot saved somewhere so that we can use them after recording for some mathematics. The camera does 60fps and it would be nice if we cold do the analysis with 60fps to, but if we would get 30fps it would be ok at this time. Our computer has an intel centrino duo cpu with 2.0ghz but the problem is that the image analysis has to be in an while-loop because it has to work continously. Labview uses only one of the two cpu`s in an while-loop, and that the reason why we have much less power....
thank you very much for your answer
Thomas
