Machine Vision
imaq image display control with ROI
How do I replace the IMAQ WinDraw with Image display control, and get the same results. That is how to get the ROI from the windtoolspalette on the Image display control, then analyse the ROI, Thanks
(3,656 Views)
hi Trinight
Now you get all the ROI information in the image itself. You can get it using propoerty nodes.
Further, the windtoolspalette is useless as you can set the tools you want to show by right-clicking on he image control
Cheers
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,645 Views)
Again thanks, I revised my vi but something wrong and I don't know why, so I upload it again, Can you teach me how to use the property node correcttly?
帖子被trinight在01-18-2006 08:21 AM时编辑过了
(3,642 Views)
Here is how I would do it...
but I would not vote for the use of a direct ROI set up on mouse action : you cannot modify it...
Cheers
Doc-doc
Doc-Doc
(3,630 Views)
Thank you very much. It seems solved my problem 🙂
(3,616 Views)
