Machine Vision
identify numbers in a aquired picture
hello,
is it possible that LV (Vision tools) identify numbers or letters of a aquired picture? I tried this with "Imaq Read LCD.vi", but it doesn’t work. The picture isn’t a LED or LCD picture. I use LV 7.0.
Is anybody there, who know a answer?
greetings zäpfle
(4,787 Views)
Unless you are reading a seven-segment LCD, the RealLCD.vi is probably not going to work.  Instead, you might consider the Optical Character Recognition (OCR) tools that come with the Vision Development Module.  If I remember correctly, these tools were added to the Module in version 7.0.
Also, if you post a few images of what you're trying to read, perhaps the members of this forum can help recommend other strategies.
Kyle V
(4,774 Views)
Hello Kyle.
I am also wondering about the version of the Vision Development Module that introduced the trainable OCR. I think it was 7.1.
Hello zäpfle: Which version do you have. As Kyle pointed out, using OCR should be the better choice.
Regards, Guenter
(4,766 Views)
As usual, Guenter is right.  The OCR tools were not added to the Vision Development Module until version 7.1.
Before you explore upgrading your software, you might consider posting a few images to the forum to see if we can test the OCR tools first.
Thanks again, Guenter!
Kyle.
(4,760 Views)
hello,
thanks for the quick answer.
I try to identify this code (it is only a example) and I use 7.0 (LV and Vision Development ).
(4,758 Views)
Zäpfle,
The OCR tools inside the NI Vision Development Module worked well on the image.  Here's a screenshot.
Kyle V
(4,751 Views)
hello Kyle V
it looks fantastic, that means I need at least the NI Vision Development Module 7.1
zäpfle
(4,742 Views)
