Hello Swedlin,
IMAQ WindDraw is a VI that is included in the IMAQ Vision toolkit (see http://sine.ni.com/apps/we/nioc.vp?lang=US&pc=mn&cid=1305 for ordering information).
If you are tring to run examples that include IMAQ WindDraw (or any other functions that are in IMAQ Vision), a dialog message will prompt you locate the VI manually (because the initial search failed).
- Installing IMAQ Vision for LabVIEW will remove the message, and the examples will run.
