Machine Vision
how to increase avi read rate
Hi, Im reading in an existing video file and then analysing each frame for when an led comes on. This will be done using histograms or intensity methods. The problem i have is that it does this in real time. As in when i run the program it will pull each frame and analyse at the frame rate of the video. Ideally I would like to do this as fast a possible instead of waiting the 10 or so seconds it takes for the LED to come on.
In short I would like to know how to read the frames faster than the frame rate, and analyse these so that I can find the frame of interest?
Thanks for any suggestions.
Labview 14.0, Labview 12.0
CLAD
Mechanical Engineering Student
Message 1 of 13
(4,093 Views)
Remove the delay.. 🙂
Message 2 of 13
(4,090 Views)
there is some method to increase it
send your vi I could tell you witch one is better for you
Message 3 of 13
(4,087 Views)
Here is the VI. As far as I know i haven't done anything with a delay
CLAD
Message 4 of 13
(4,085 Views)
I can see the delay of 25ms.. o.O
Message 5 of 13
(4,078 Views)
I thought about that but it doesnt affect it. When i set the delay to 0 nothing changes. the producer loop is what I need to speed up. the images I believe are being sent out to the queue at the frame rate per second of the video
CLAD
Message 6 of 13
(4,073 Views)
i use there method for incease speed
1 cut ROI
2 use all CPU core
3 reduce number of frame that you need
for example some times you just need half of frame or every there frame just one
check witch is better for you
Message 7 of 13
(4,063 Views)
A trick I would consider is to do two iterations.  In the first iteration, look at every tenth or twentieth image, and check if the LED is on.  Once you find an image with the LED on, you have to go back and analyze the last ten or twenty images to see which one the LED turned on in.  This will be much faster than checking every single image.
Bruce
Bruce Ammons
Ammons Engineering
Message 8 of 13
(4,055 Views)
hi im now going to use histograms but my problem is the same. I'm using a producer and consumer arctitecture. How would i be able to implement your suggestion of using two iterations?
CLAD
Message 9 of 13
(4,005 Views)
did you check last vi that i sent to you ?
Message 10 of 13
(3,982 Views)
