Machine Vision
how to control CC(1-4) on a PCI-1426 cam link board using VB6
I am testing an NI PCI-1426 camer link board with our thermal imaging camera.  How can I set the CC(1-4) outputs to the camera?  I'm using VB6 with measurement studio.
(3,269 Views)
Nevermind, I figured this out using the trigger lines.  But now I have to figure out how to set the default status of the trigger lines to False instead of True.  Anybody know how to do this?
(3,258 Views)
Josey--
     When you set up to do your acquisition, you will have to set up the triggering aspect.  If you are using LabVIEW, then the "Configure Trigger 2"  VI has a terminal where you can set the trigger polarity.  Check that out and look at the help, let us know if you have questions
John H
(3,230 Views)
