Machine Vision
get an image from USB cam without NI VIsion Acquisition
HI
I am looking for a way to capture images from USB cam without using a paid library ImaxDx for Labview.
Have you any ideas?
(3,567 Views)
Hello MaxEngee
Off hand, I suppose you could run the third party capture software in the background and have a LabVIEW scan the target directy for changes/new images and import the image as necessary.
In the mean time, if you install the NI Vision Acquisition Software, you do have a 30-day trial period so perhaps you may consider exploring the environment to see if it is right for you.
https://www.ni.com/en/support/downloads/drivers/download.vision-acquisition-software.html
Thank you for choosing National Instruments!
Sincerely,
Greg S.
(3,499 Views)
I have found http://sine.ni.com/devzone/cda/epd/p/id/5030.
This is free driver for USB cam for Labview
(3,492 Views)
Hi MaxEngee,
Does it really "free" coz as I know it's part of NI Vision package that's quite expensive :(. Can you post your code example
Thank you in advance!!!
HAND
(3,400 Views)
