â07-04-2014 10:52 AM
Hello Guys.
I'm a newbie in here and also a newbie in labview stuff. I'm currently working on my final project and face a handicap in image processing. I need to get characteristic extraction as a variable in artificial neural networks. Does anyone knows how to get characteristic extraction from image grayscale image? To find its characteristic of energy, contrast, homogenity, entropy, level of grayscale, and standard deviation.
Thanks in advance
â07-05-2014 03:00 AM
@kak_iguuun wrote:
Hello Guys.
Thanks in advance
I am not sure about what you mean by energy. You can try imaq histogram function. that will give you gray scale value and standard deviation.
â07-05-2014 05:11 AM - edited â07-05-2014 05:12 AM
to my knowledge there is no Labview function that can perform what you want directly. You would have to code it yourself.
Whenever I am in doubt and need some extra info about algorithms regarding the image processing I tend to check Matlab documentation first (the also cite different papers). In my opinion no other SW environment comes close to the number of implemented algorithms in image processing (there are also a lot of users/programers that implement all kinds of algorithms). So:
http://www.mathworks.com/help/images/ref/graycoprops.html
http://www.mathworks.com/help/images/ref/entropy.html
You would need to implement the algorithms yourself in Labview or create a .dll in Matlab, that can be called in Labview (have never done this). Assuming you have Matlab. If not, your only option is the former.
K
â07-28-2014 05:54 AM
Hi, as muks advice you, using imaq histogram you can find some data . If you send some details about the desired algorithm may be i can hshare you some idea.
â07-28-2014
04:55 PM
- last edited on
â07-23-2026
04:07 PM
by
Content Cleaner
Sorry, I missed this when you posted it a couple of weeks ago. Have you looked at IMAQ Cooccurrence Matrix? There are a number of Haralick features you can evaluate, including entropy, contrast, homogeneity, energy and so on. As well as giving you the GLCM. There might be other useful routines under Image Processing/Texture.
The VI help is really poor (not even listing the features available) but in the Vision Concepts manual, there is a good explanation of the features (though the equations all state "Entropy" -- if someone official could flag this as a CAR that would be good!!).
â07-28-2014
04:58 PM
- last edited on
â07-23-2026
04:10 PM
by
Content Cleaner
While I'm at it with the errors in the Concepts Manual, the previous page on What To Expect also has errors, particularly in the section on Scale Variation which talks a couple of times about rotations of 10 degrees - presumably should be scale changes of 10%. Add that to the CAR please!
â07-29-2014
12:34 AM
- last edited on
â07-23-2026
04:11 PM
by
Content Cleaner
Nice one! Was not even aware of this function!
Thanks for pointing this out!
K
