Machine Vision
error message says "missing resource file imaqdx.rc"
Using LV2010, gone back to a PC that's been unused for a while to access some old vision programs. On the block diagram the IMAQDX property node is disconnected and while loading the file I get a message that says, "missing resource file imaqdx.rc"
Suggestions?
(6,125 Views)
could you attach image of your code ?
I think you have problem with your vision toolkit
(6,112 Views)
Snip attched.
(6,108 Views)
Please try the following:
1. Go to control panel » add remove programs » National Instruments software (double click this), and "remove/delete" the following items:
NI IMAQ
NI IMAQ runtime
NI IMAQdx
NI IMAQdx runtime
NI IMAQ IO
NI IMAQ IO runtime
(and any other item related to "IMAQ")
2. Reboot the PC
3. Install this:
NI Vision Acquisition Software February 2014
http://www.ni.com/download/ni-vision-acquisition-software-february-2014/4584/en/
4. Reboot the PC
5. Verify that the problem has been resolved.
Daniel C.
(6,099 Views)
what danubio told is last chance to you to solve your problem
but before to do that because it take so time to do
send your vi I try to test your property node problem if I could not find any problem you should do what danubio told you
(6,093 Views)
Hello Hatef.fouladi,
That is a kind offer but I am pretty sure the problem is with my IMAQ. I am going to unistall and re-install. I will let you know how that works out!
Thank you.
(6,090 Views)
Accepted by another_novice
For anyone following this discussion, I did resolve the error message, but only by completely removing everything NI-related and then reinstalling. A major PITA!.
(6,015 Views)
