Machine Vision
error 0xBFF69026
Hi
I had a problem with Vision Acquisition modul. Therefore I had uninstalled Vision Acquisition Software, Vision Development Module with Vision Development and Vision Run Time. I had installed Vision Acquisition Software, VDM with Vision Development and Vision Run Time. In NI MAX I could start my camera but whe I would like to use Vision Acquisition in Labview I had received the following error: NI IMAQdx: (Hex 0xBFF69026) License not activated.
I had checked the license activation i NI License Manager and everythink was OK. Could you please help me to resolve the problem? I am working on 64 bit OS, Windows 7.
(5,458 Views)
(5,430 Views)
I have deactivated and activated the vision acquisition software again but the error is the same.
(5,386 Views)
Hi
I bought a license for labview installation on 5 computers. I read from this link: https://www.ni.com/en/support/documentation/supplemental/18/licensing-national-instruments-vision-so... that:
When you buy the NI Vision Acquisition Software you receive:
  1. The NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O image acquisition drivers.
  2. A (single) license for NI-IMAQdx on one computer.
I installed labview on two computers. On the first one imaqdx is working and I can make software applications using vision acquisition. On the second computer I have problems with configuration of vision acquisition and I can't use my webcam in labview. Is it possible that I have a single license for NI-IMAQdx used by my first computer and therefore it is not possible to use the same license to the second computer?
(5,381 Views)
Did you contact your local NI office/representative?
(5,379 Views)
