03-23-2006
01:04 PM
- last edited on
04-17-2025
05:51 PM
by
Content Cleaner
I am a new administrator in my company, and I found this in my old machine, I know is a PCI-can card and I know is 1 port, I want to know what model is this ? can any one tell me ? I only have tthe card right now ? what else do I need to use the card again ?
I do some research on PCI-CAN Series 2 Interface and found that this card has not of model. but do not match the one I have ?? thank you
03-23-2006 01:30 PM
03-23-2006 01:35 PM
Could you please provide us the numbers (and letters) that are on the white stickers? The one in the bottom left corner is probably the part number, but both would be helpful.03-23-2006 01:45 PM
03-23-2006 01:46 PM
03-23-2006 01:53 PM
Your part number is 184726C-01. That means it should work fine with the current drivers. You can also download the current software & hardware manual by searching for NI-CAN manual.
Bruce
03-23-2006 03:12 PM
03-24-2006 08:11 AM
This is an obsolete model, so it isn't in the catalog any more. It looks like it is the standard PCI-CAN (series 1) card, though. I think the only way to be sure is to install the NI-CAN drivers, then install the card. It will recognize the card, then you will be able to see what model it is in MAX.
Bruce
