Machine Vision
detect framegrabber (NI PCI-e 1429)
I've got the following situation:
There are several pc's (around 50) that have an executable running our test-sequencer. Some of these pc's will be equiped with the NI PCI-e 1429 framegrabber.
Not all of these pc's have the NI-IMAQ component installed, only the pc's equiped with the framegrabber.
Since the NI-IMAQ is not always installed using these VI's the "claim" the framegrabber to detect it is not an option. These VI's are not executable if the NI-IMAQ is not installed, so the test-sequencer is not happy with that.
I tried accessing the MAX through activex to find the framegrabber but this is not documented by NI.
How can I detect if the framegrabber is installed?
Paul
Message Edited by Dwanny on 02-23-2007 08:22 AM
(3,259 Views)
Hi Paul,
Maybe you could use the error generated when there is no camera.
See the attached VI.
Bas van Dijke
AE, Netherlands
(3,235 Views)
