Machine Vision
descriptors for multiple ROI's
You are getting the error (I assume from the top part of your image) because the Global Rectangle defines the area encompassing all of your ROIs.  When you use the ungroup function, then each ROI has its own parameters for its Global Rectangle.  At least that is my guest.  The attached does work though.
Randall Pursley
Message 11 of 16
(2,296 Views)
Alternatively, if you just want to do the ROI Profile on the first contour, see the attached image.
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
Message 12 of 16
(2,291 Views)
I tried Greg's solution and it worked perfectly. Thanks again for all the replies.
Message 13 of 16
(2,272 Views)
i am trying to read a book using OCR. i am able to read a single line correctly. bt when there is more than one line, there is a problem with ROI. i want an ROI around each line to read it..can u help me with this?
Message 14 of 16
(1,465 Views)
dear nithi.tr
I have a problem exactly like your problem. If your problem is solved guide me, please!
Message 15 of 16
(1,285 Views)
Hi TANDIS,
You'll get more visibility by creating a new thread. It seems like this thread pertained to a different event and came to resolution in 2008. This will bring it more attention. I hope this helps!
- Kale
Message 16 of 16
(1,262 Views)
