01-07-2010 02:44 AM
01-07-2010 03:11 AM
01-07-2010 03:19 AM
01-07-2010 03:38 AM
You can extract the whole coin using thresholding and then using particle filter you can sort them with respect to their size and diameter. thickness can also be measured but it will be a realtive one since you want to use a single camera. Keeping the camera tilted at an angle and ensuring very good positional accuracy of the object (Coin), it can be measured.Post back if you are stuck.
AND STICK TO THIS THREAD!!!!!
01-07-2010 10:31 AM
Hi, Muks,
I'm so interested in what you talked about. Do you mind if i ask the similar question here?
For coin sort, can we just use pattern matching 2 to compare the two images of coins? Sometimes, we may get the image of coins from USB Camera first, learn the template and compare the images of coins later?
Really appreciate it.
Guangli
01-07-2010 10:35 PM
guangli wrote:Hi, Muks,
Guangli
Sorting with respect to size and dimension will not be possible by only pattern matching. In fact when it come to measuring you have to ensure that the area of intrest (COIN) covers the maximum area in the image as much as possible. This wil make sure you dont waste pixels. Distinguishing the coins wrt to some mark can be done in pattern matching.
01-08-2010 12:33 AM
I'm unable to run the vision assistant express VI. It says.." Vision assistant requires a minimun resolution of 1024x768.
I tried changing the screen resolution , even then its not working
01-08-2010 12:40 AM
01-08-2010 12:45 AM
01-08-2010 12:48 AM
