10-22-2009 05:53 PM
Hello.
I am using a Imperx 210L camera with a PCIe 1427 camera link board. MAX sees the camera, but does not allow me to choose the correct camera file. When I try, it says:
Error 0xBFF60135
The requested bit stream is not compatible with this device
However, if use the Imperx 1M48-LC camera file, MAX does not complain. What could I be doing wrong? I just reinstalled the VAS2009 package, to no effect. Thanks in advance.
Solved! Go to Solution.
10-23-2009 04:22 AM
10-23-2009 12:36 PM
muks wrote:
refer here
Thanks, but the suggestions do not help. I have installed the latest version of the vision acquisition software (VAS 2009).
I guess I will try and make my own camera file. It is just odd that the camera file that is supposed to work with this camera fails so dramatically.
10-24-2009 06:59 PM
10-27-2009 07:09 AM
