Machine Vision
caliper calibration not working
I am using the IMAQ caliper tool to find edges and measure the distance between the jaws of a real caliper. My problem is as follows:
When I set the real caliper to a measurement of 1 mm and use the caliper vi to measure the distance between the jaws I get a pixel measurement of 45.59 pixels. I then configured the vi to divide the distance output of the caliper vi (in pixels) by the 45.59 to achieve 1 mm. However, when I then move the real caliper to a measurement of 10 mm my caliper vi measurement reads 3.9mm. This may be a painfully obvious answer, but I am new to machine vision and am confused by this. Can someone please point out where I am going wrong with my calibration?
Best Regards,
Nicholas Carroll
(6,450 Views)
You need:
Telecentric Lens
Diffuse Backlight Illumination, preferably collimated
16 Bit Greyscale Camera
A distortion-corrected image
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(6,443 Views)
what you are describing is not a proper calibration. You have radial and perspective distortion in your measurements (which you clearly do, based on what I can understand from your problem). Did you use the planar calibration grid? Take a look for example at the "Perspective Calibration" in the NI Example Finder.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(6,442 Views)
Thank you very much. I am using a 12 bit greyscale camera. Is that not sufficient? I only ask because you mention a 16-bit camera. I definitely need to get the lighting and telemetric lens though.
(6,438 Views)
I did not use the planar calibration grid. I was unaware of its existence. Thank you for bringing it to my attention!
(6,437 Views)
12 bit is fine.  I suppose it all depends on the level of accuracy that you need.
(6,435 Views)
Hi Sir,
Have you fixed your issue ?
I am also new, and would like to learn something of vision, such as capture the contour, calculate the distance.
Are you still there ?
Thanks.
Learning from other people, sharing ! bruce.xw.zhou@foxmail.com
(2,042 Views)
