Good Day!
I've been working with Labview 8.0 and Vision Builder AI 2.6. I've migrated four inspections scripts into four separate VIs and integrated them into just one. The inspection is working fine. However, my problem is that sometimes I do need to recalibrate the settings (eg. for edge detection sometimes i must change the threshold or the minimum value) depending on my needs. And if I change the settings and run the inspection it will be fine. But whenever I exit from Labview and open the VI again on a later time the settings will just be returned to the original values from when i first migrated. And to change the values to the ones i now use each time i open the VI to run an inspection is really tedious and somewhat annoying. Is there a way to save the last settings? I've tried both save and save all. But it is still the same.
If anyone could help. Thanks.
Joel Tucit
