Machine Vision
basler runner rul1024-57gm GigE line scan camera with broadcom network card
Hi, I am learning to use a basler runner GigE line scan camera with labview but meet with some problems, please help me.
My software and hardwares:
labview 8.6, vision acquirition software 2010,
basler rul1024-57gm camera, broadcom Netlink(TM) Gigabit Ethernet Network Card (It not a intel pro 1000, so the driver is the also the broadcom driver).
Q1: In the max, there appears two cameras, while I only connect one. There is a red X in the other one, and a error of camera in use.Capture1.PNG
Q2:
The camera can acquire image, but in the camera attributes, there is no information of trigger, so it seems I cannot set the trigger in labview, while the camera does support trigger mode.
Message 1 of 8
(4,841 Views)
Hi, I have found the reason, I uninstall the driver the camera company supplied, there is only one camera in MAX now, and the trigger setting options also come out.
But the problem is it do now acquire image now, it gives out error 0xBFF69031,
The system did not receive a test packet from the camera.  The packet size may bee too large for the network configuration or a firewall may be enabled.
I have disable the firewall, and I decrease the packet size form 8000 to 4000, it still do not work.
Please help.
Message 2 of 8
(4,838 Views)
Hey ustcmiaor,
There are a few items we can try from Troubleshooting GigE Vision Cameras for your device.  Once opening this page, navigate to 'The camera can be opened in MAX, but it does not acquire images.'  I suspect your issue pertains to the High Performance Driver.
Let me know how it goes!
Lynn
Senior Systems Engineer
Message 3 of 8
(4,825 Views)
Accepted by ustcmiaor
Hi Lynn,
I read the page and do find the solution. In fact, I just need to further reduce the packet size to 1500. It works well now.
Thank you~
Message 4 of 8
(4,823 Views)
Hey,
I'm glad to hear its working well now! Enjoy!
Lynn
Message 5 of 8
(4,806 Views)
I have the erroe message. How do you reduce the packet size?
Thanks for your help!
Message 6 of 8
(4,499 Views)
You can reduce the packet size within Measurement & Automation Explorer in the Acquisition Attributes tab. (See Case 3 in Troubleshooting GigE Vision Cameras under 'The camera can be opened in MAX, but it does not acquire images').
Lynn
Message 7 of 8
(4,491 Views)
I indeed read the pages. I have had needed to reduce the packet size and disable the firewall. Now it works well.
Message 8 of 8
(4,489 Views)
