I am trying to run four cameras through the PCIe-8244 USB3.0 frame grabber and collect videos from all of them independently. This is proving to be an extremely difficult task. (LabVIEW 2013)
So far I have IMAQdx working fine for two cameras to display to the front panel. However as soon as I try to record, I cannot press any other controls on the front panel, which makes starting the recording of other cameras impossible, below is a pic of what is running. I have tried putting the avi Write2 function in timed loops or just with timers and in either case I can only gather one video at a time. However the cameras are still running in their independent loops without an issue. The timed loops shown are initiated through an event structure by a record button in the camera's independent capture loop.
Attached is the code in question, please ignore my attempts at debugging indicators.
I do plan on expanding this to the full four cameras that PCIe-8244 supports.
