Machine Vision
acquisition speed with IMAQ Grab
Hi
I am building a vi that uses the IMAQ Grab function. Because I want a big number of images I surronded the function with a for Loop. It works weel unfortunetly I only can acquire 4 images a second and I wanted at least 10. Can you help me.
Thank you
(4,351 Views)
I am far from an expert, but this is something I have done before.
Are you simply grabbing images or are you also saving them?   What hardware/software are you using?
If you post up your VI it could be checked.
(4,348 Views)
Well I am using labview 8.2 with Ni Vison 8.0. I am not saving the images. I don´t even need to see them. I am just trying to acquire specific data out of them. I use the Ni Vison and then I build a vi and work with that. when Ni vision builds a Vi he uses the snap function, so I change it to grab in order to make the acquisition it faster. The program serves to acquire data from animals, so if the acquisition is slow a lot of informations his lost. Subtracting functions don´t improve the speed so I think the problem is in the grab function.
Thank you
(4,339 Views)
Hi
You have to put the Init, Configure grab and Close out of the for loop. The whole initialization and closing sequence takes a long time and you don't have to do it for each grabbed image.
Vladimir
View my profile on LinkedIn
(4,325 Views)
Mr Vladimir
Your sugestion doesn´t seem to work. I put the grab functions out of the loop cicle and I have an error like this :
Error -1074396080 occurred at IMAQ Extract Single Color Plane
 Invalid image type.
His there anything else you can sugest?
Thak you
(4,322 Views)
The grab function itself must stay inside the loop, just the init and configuration has to be put outside.
Vladimir
(4,320 Views)
