08-24-2007 03:38 AM
08-31-2007 01:34 AM
09-04-2007 09:25 AM - edited 09-04-2007 09:25 AM
Message Edited by JohannS on 09-04-2007 09:27 AM
05-06-2011 03:37 PM
I am currently experiencing a very similar problem with an Orca camera and IMAQdx. When operating properly the camera loads up settings and our baseline (for a dark pixel) is about 200AU. However sometimes for no obvious reason the camera will reset to some values - typically around 2000AU for a dark pixel. Unlike the poster above when we acquire a .tiff image the intensity remains at 2000AU. On screen during life feed the images appear over-exposed. In MAX a lot of changing of settings and values can often force the cameras back into their proper settings - however we haven't idenitfied a proper sequence for this - it appears just random settings changes will eventually force the system to move to the correct baseline.
This issue is also happening across multiple cameras we are working with. All are Hamamatsu ORCA-03G.
Unfortunately we cannot yet figure out how to get the cameras to change from the high baseline readings to the low baseline readings programmatically.
If anyone has any suggestions they would be greatly appreciated.
Many thanks,
David
