Machine Vision
Write image to file without lost
Hello everyone,
I'm working with PXI-1411 on RT system. The frame rate is 25 per second. I used IMAQ write file 2 to save images in seperated files. But it caused always images lost. Because the velocity of IMAQ write file is much slowier than velocity of image acquisition. But i can't save images to AVI file., because it doesn't work on RT system. Do you have any suggestions to solve this problem. Thank you very much.
(3,200 Views)
(3,193 Views)
Also if you can then attach a screen shot to show how you have tried.
(3,192 Views)
I'm so sorry the images are too large to post. If you want them, I can send you a E-mail. Thank you very much.
(3,185 Views)
Hello Zhongge,
yes you are rigth at the moment the avi function dosent support rt targets. But you are able to use the streaming function for that.
Link: http://zone.ni.com/devzone/cda/epd/p/id/6000
Kind regards,
Elmar
(3,154 Views)
