10-17-2009 12:44 PM
10-19-2009 10:20 AM
Hi TJK,
I suspect some sort of IP address mismatch. Is the camera setup in the default, out-of-the-box configuration (with DHCP and Link-Local-Addressing)? Normally we recommend having it set like that and letting the PC use link-local-addressing as well.
It is possible the Basler software and camera were set up with forced IP addresses. I'd check with Basler's IP configuration utility and see how the camera is configured.
Eric
10-19-2009 11:33 AM
Eric,
It turns out we had to download the vas2009_downloader.exe; it appears this software installed missing elements of NI-IDAQdx; it is now installed and we can see the camera in MAX but it is selected MAX Crashes. Any ideas?
10-19-2009 12:08 PM
To be more specific...
-The camera was functioning properly prior to running MAX (could be detected and used in Basler's Pylon software)
-The camera is in its default format, IP address is determined automatically and is not forced
-Upon launching MAX, the device is detected and populated in the Devices and Interfaces sub menu under IMAQdx (2 devices originally showed up, cam0: Basler <camera info> and cam1: Basler Drivers. After uninstalling the Pylon software at the request of a service engineer, cam0 is all that remains)
-Selecting the device in max creates a long hourglass pause, but the snap and grab buttons are eventually usable
-Clicking either snap or grab results in a timeout
-After running MAX the camera is no longer functioning properly in the Basler software (shows up as a device but the image aquisition is white)
-Another apparently completely random side effect is the shut down of my Telus internet stick (used only for internet connection, not related to any devices in MAX)
After contacting NI support regarding the issue, some basic steps were taken to diagnose the problem. No progress has been made, but all security settings on Windows XP have been shut off (firewall, virus, etc), the Basler supplied software was completely removed to negate potential driver conflicts, and we're in the process of repairing the IMAQdx software. Next step is to remove the IMAQdx software and do a complete re-install.
Leddy - colleague of TJK
10-19-2009 01:22 PM
Hi Leddy,
The extra camera you are seeing when the Basler software is installed is likely because their software installs a DirectShow wrapper around their Pylon driver, allowing you to use their camera in DirectShow applications. Starting in Vision Acquisition 2009, IMAQdx is able to acquire images from DirectShow as well, which means you will see that Basler DirectShow interface. I don't think it should cause any problems having it there though, but you can disable that from Basler's installation if you have no need for it.
I'd be interested in finding out more about your system's network configuration. If you could paste in the contents of "ipconfig /all" and "route print" from the command line that might help.
Eric
10-19-2009 02:24 PM - edited 10-19-2009 02:25 PM
C:\Documents and Settings\*******>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : *******-pc
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-26-9E-05-8F-05
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . : 169.254.247.176
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Ethernet adapter Wireless Network Connection 2:
Description . . . . . . . . . . . : Broadcom 4322AG 802.11a/b/g/draft-n
Wi-Fi Adapter
Physical Address. . . . . . . . . : 00-26-82-06-A9-4B
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Ethernet adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Sierra Wireless USB 598 EVDO Network
Adapter
Physical Address. . . . . . . . . : 00-A0-D5-FF-FF-85
C:\Documents and Settings\*******>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x10003 ...00 26 9e 05 8f 05 ...... Realtek PCIe GBE Family Controller
0x10004 ...00 26 82 06 a9 4b ...... Broadcom 4322AG 802.11a/b/g/draft-n Wi-Fi Ad
apter
0x10005 ...00 a0 d5 ff ff 85 ...... Sierra Wireless USB 598 EVDO Network Adapter
Active Routes:
Network Destination Netmask Gateway Interface Metric
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
169.254.0.0 255.255.0.0 169.254.247.176 169.254.247.176 30
169.254.247.176 255.255.255.255 127.0.0.1 127.0.0.1 10
169.254.255.255 255.255.255.255 169.254.247.176 169.254.247.176 10
192.168.1.0 255.255.255.0 192.168.1.100 192.168.1.100 30
192.168.1.100 255.255.255.255 127.0.0.1 127.0.0.1 30
192.168.1.255 255.255.255.255 192.168.1.100 192.168.1.100 30
224.0.0.0 240.0.0.0 169.254.247.176 169.254.247.176 10
224.0.0.0 240.0.0.0 192.168.1.100 192.168.1.100 30
255.255.255.255 255.255.255.255 169.254.247.176 169.254.247.176 1
255.255.255.255 255.255.255.255 192.168.1.100 10005 1
255.255.255.255 255.255.255.255 192.168.1.100 192.168.1.100 1
Persistent Routes:
None
The second camera could be exactly what you're describing, however selecting that specific option under the IMAQdx devices menu (cam1:Basler) causes MAX to shutdown completely. Additionally, the menu selection no longer exists after the removal of the Pylon software.
