Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
09-26-2019 03:04 AM
IC3173's network card eth0 is set to static IP address. If you use ifconfig to query the network card, sometimes the return information contains IP address, sometimes not. Why? Please help to analyze the causes of the problem, thank you!
Thanks!
We'll be in touch soon!
