Machine Vision
When using Get Image in NI Vision Assistant, the run button cannot be clicked and images cannot be obtained
Recently I have been learning to use the NI Vision Assistant.I had trouble trying to use Get Image.
  • Following the instructions, I set the path to get the image, and click OK
But the run button is grey and cannot be clicked
  • If I just randomly add an original image
The run button is ready to be clicked
I don't know what the problem is, but I have a feeling there must be something wrong.
I hope someone can help,please. Thank you!
(1,775 Views)
Hi there,
The best way to start learning something is by following the Tutorial.
NI Vision Assistant Tutorial
(1,492 Views)
