12-16-2009 03:31 PM
i'm on senior project for my study in bachelor degree.
and my project is to create an orientation for robot FANUC to pick a thing by using CCD camera.
my problem is when i transfer my VA to labview module by using create Labview VI function
1. the module doesn't show the calibrated output from pattern matching
2. in the image out panel doesn't show how their matching it shows only the image
how can i fix this?
Solved! Go to Solution.
12-16-2009 04:28 PM
12-16-2009 10:19 PM
12-16-2009 10:42 PM
12-16-2009 11:54 PM
12-17-2009 08:46 AM
12-17-2009 01:47 PM
Hi NuMetal,
The VIs with IVA infront of the name are created by the Vision Assistant. You can find the VIs in \vi.lib\vison\Vision Assistant Utils.llb. LabVIEW does not normally check here when loading VIs, so that is why it cannot find it. I have also attached the subVI. You may also want to consider using the "Pattern Matching Example.vi," found in the NI Example Finder under Toolkits and Modules >> Vision >>Functions.
I hope this helps!
Kristen H.
12-17-2009 10:17 PM
12-17-2009 10:53 PM - edited 12-17-2009 11:00 PM
12-17-2009 11:44 PM
