09-26-2010 10:05 AM
Hi, i have installed an evaluation copy of the Vision Acquisition software along with the Vision Assistant. The problem is that after installing NIs USB camera plug-in http://zone.ni.com/devzone/cda/epd/p/id/5030 it does take a picture once, but than it stops detecting the camera and not only that, the camera is not detected by my laptop. I am using LabVIEW 8.6 with Windows 7 on a Compaq Presario V3000 Laptop.
Solved! Go to Solution.
09-27-2010 01:55 PM
If you're using a current version of Vision Acquisition Software (2009 or later), you don't need to use the IMAQ for USB add-on you referred to. Instead, use the NI-IMAQdx driver which installed with Vision Acquisition Software. If you look in Measurement & Automation Explorer, you should see your USB camera under Devices and Interfaces»NI-IMAQdx Devices. You should also be able to find LabVIEW examples through the Example Finder under Hardware Input and Output»IMAQdx»High-Level.
09-28-2010 12:35 AM
Hi, Thanks for your reply. Can i use Vision Acquisition 2009 with LabVIEW 8.6?
09-28-2010 01:36 AM
Yes, is seems to be you can:
http://digital.ni.com/public.nsf/allkb/6B55FF09D1FBD3108625719600650B7C
http://digital.ni.com/public.nsf/allkb/244E6DDF9A92A6CD8625730100629047
Andrey.
02-28-2011 06:05 PM - edited 02-28-2011 06:11 PM
I have installed Vision Assistant 2010 evaluation version only. I am running it on Asus EEE PC, with Windows 7 OS. Whenever I try to acquire images with my USB camera, I get an error that I don't have IMAQ drivers installed, and I can't acquire any images. I have tried installing the driver ni_imaq_usb_installer86.exe, but this driver hasn't installed at all on my system. Does that mean I have to install the Image Acquisition 2010 software as well as Vision Assistant for the USB camera to function properly? Or do I have to do something else?
Please give me a step-by step instruction, as I'm fairly new to Windows 7
Thanks for your help,
Yuri.
02-28-2011 06:43 PM
Hi Yuri:
USB camera support is now included in the NI-IMAQdx driver. The IMAQ for USB driver only installs support for 8.6 hence the version number in the installer. To install the NI-IMAQdx driver, download Vision Acquisition Software 2010 and run the installer. Just be aware that NI-IMAQdx requires a license although you can use it in evaluation mode for 30 days.
03-04-2011 08:50 AM
Hello Alex,
Thank you for your suggestion. It works perfectly and now I can acquire images from my webcam.
