10-01-2020 09:30 AM
I have recently upgraded to Vision assistant 2020. When I try and generate a VI for my script I get errors because the program can't locate niRio_Find Devices.vi and another Rio related vi. Not seen this kind of problem before with vision assistant. Does anyone know where these files might be located?.
10-01-2020 11:20 AM
Install the RIO driver. This should fix this issue.
10-12-2020 12:02 PM
I suspect you are probably right. I tried downloading the RIO drivers but my PC hard drive was full, so no chance to test as yet.
I don't use RIO and don't recall downloading the drivers before. Never had a problem until v2020. It's a pity because the code generation feature in Vision Assistant is extremely useful.
Thanks for the reply.
11-13-2020 02:42 PM
Had the same issue. Downloading CompactRIO fixed it!
Thank you 🙂
