Terry,
My suggestion would be making the Vision window a child panel of the main panel, then programatically show/hide it.
You can make it a child panel using "Make IMAQ Child", which is a routine from NI. I posted a revised version of it in a recent reply here.
To hide or show the window, you can use hide/show window. Compare the terminal for the tab control to a constant for the desired page, and if equal show the window.
Bruce
Bruce Ammons
Ammons Engineering
