Machine Vision
VBAI settings for image snapshot
What settings do I need to do if my application only requires 1 snapshot every 3 minutes? Currently I have 4 frames/sec which I really don't need. Can I trigger GigE camera on demand and take only 1 sample rather than scanning all the time.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,341 Views)
Hello test_man,
There are two methods that I would suggest especially if you are fairly new to the Vision Builder AI software.  If you can externally trigger your camera, you can set up a trigger signal to send every three minutes.  Another option is to use software timed acquisition, by putting in a delay.  The time delay function can be found in the "Use Additional Tools" tab.  With software timed, it should be noted that you will be relying on the OS clock.  I hope this helps get you started.
Vu
(3,325 Views)
