Machine Vision
VBAI - "Not enough memory to complete this operation"
I have a problem with VBAI 2010. I started a fresh new inspection:
- "Simulate Acquisition" and select a 9MB jpg file (800dpi, grayscale, 2000x27716pix) - no error
- "Detect Texture Defects" - and click "New" on the "Texture Classifier File Path" dialog box
- "NI Texture Training Interface" new Window pops up, and then it crash with error "Not enough memory to complete this operation" (see attached file)
- Task Manager shows that the virtual memory VBAI used is ~1GB!
Why did this happen? Here are my computer configuration:
- 3GB RAM, 3.0GHZ, Windows XP
- Paging file is 4603MB in C:\. I checked with defragment tool, it is in one fragment (one continuous piece)
Please kindly help.
(3,655 Views)
In 2017,coming to 2018,I can still get this error in vbai,great.
(2,746 Views)
Try using the the 64-bit version of VBAI that was introduced a few years ago with a machine that has at least 6GB of RAM to get better performance. 32-bit applications are limited to 3GB and with large images this can quickly run out of contiguous memory.
Hope this helps
Brad
(2,742 Views)
