Machine Vision
VBAI 2009 SP1 and VBAI 3.6 side-by-side PC installation
Is it possible to install VBAI 2009 SP1 on a host PC without either breaking the VBAI 3.6 installation and/or the ability to connect/configure remote targets running 3.6?  (I have several CVS units that are running 3.6, which I still need to be able to connect to.)
Mike
(2,905 Views)
VBAI supports side by side installation, so you can have VBAI 3.6, VBAI 2009, and VBAI 2009 SP1 all installed on you host PC. You can only have 1 version of VBAI on a target, and you have to use the matching version of VBAI on your host to communicate with it.
Also be careful because you can open older inspections with newer VBAI versions, but you cannot save for previous. So if you save an inspection with VBAI 2009 SP1, you will not be able to open it with earlier versions of VBAI.
Hope this helps,
Brad
(2,904 Views)
Yes.  Thanks again, Brad.
Mike
(2,894 Views)
