07-05-2011 10:05 PM
I'm developing a GigE Vision Camera.
Now I have met the same problem http://forums.ni.com/t5/Machine-Vision/GigE-Vision-Camera-Connection/m-p/1198767
I wonder how he has solved it.
And I am not sure that I understand what replier:Eric suggested ,Did he mean to copy the XML file(used in camera) to
the directory, ie C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data\XML?But now the software version I installed is Vision Acquisition 2010 August , NI-IMAQdx 3.7, No such similary directory is found!
thank you!
Attachment is my xml!
07-05-2011 10:12 PM
here is my xml file,when using our application in pc, everything is ok!
07-06-2011 09:34 AM - edited 07-06-2011 09:37 AM
I had the exact same problem last week. I went to update to VAS august 2010 and after I did it messed my system up and I kept getting the "unable to load xml file" error on my GigE camera. Some people suggested reinstalling your camera's firmware. Sadly enough, what worked for me was upgrading to a different version of the vision acquisition software. I used august 2009 instead and gave up on 2010.
edit: here's the post I made about it. Someone also suggested using the "camera file gnerator" which they linked.
Hope you can figure it out! I know how frustrating it was when I was getting this error.
07-06-2011 10:17 AM
smithers ,
thank you.
Have you fixed the problem finally?
I will try to use Camera File Generator . this is my first time to use it
God bless me.
07-06-2011 10:30 AM
Yes, I've got my camera working since then. But I was never able to update to VAS august 2010. I used the 2009 version instead and it has no problem with my xml file. Hopefully you don't have to downgrade and find a real solution. Also try reloading your camera's firmware by contacting your vendor. Good luck!
07-06-2011 10:49 PM
hi smithers:
It is sad vendor is myself. Maybe I need to downgrade to 2009 vesion like you now,this has wasted me too much time!
Could you send me your xml file as refence.Thank you!
07-07-2011 10:06 AM
Yes this should be the file
07-10-2011 09:14 PM
Hi,smithers
Thank you, is it a xml file,different from mine
