07-18-2016 06:28 AM
I am trying to capture an image from Firewire camera. It is RGB camera and I can see nice RGB images in the software provided by company. But when I try to capture image using the attached program in LABVIEW, it displays and captures only grayscale images with some weired appearance which we can see upon magnification. Please check the attached program and images and help me in sorting out this issue.
Thanks.
07-18-2016 06:34 AM
07-18-2016
07:18 AM
- last edited on
05-11-2026
02:09 PM
by
Content Cleaner
Which camera you are using?
Have you checked the camera settings in NI MAX?
https://www.ni.com/en/support/documentation/supplemental/06/acquiring-from-firewire--cameras-with-ni...
07-18-2016 08:22 AM
Thanks for the reply. It is Dage-MTI XLM 350 CCD camera. I have checked it in NI MAX. It is same. When I checked it in LABVIEW program, it displays RGB (U32) as image type. But in both cases (LABVIEW and NI MAX) images are grayscale. Please check attached images for the settings in the NI MAX.
Thanks.
07-18-2016 11:35 PM
