02-10-2020 09:27 PM
S/W : Win7 64bit, LabVIEW 2018 SP1(64bit), NI-IMAQdx 18.5
H/W : Dalsa P3-80-8K40, PCIe-1437, Extension B/D
I want to use line trigger with encoder as in the attached example.
Reading the encoder confirmed.
We also used TTL / ISO / RTSI to receive external triggers. However, I did not receive a trigger.
What should I setup to receive and use a trigger?
07-26-2020 09:11 PM
Hi side,
Were you able to solve the issue using a RTSI ?
Could you please explain and if possible post some code how were your triggering issues solved.
Will be great help.
Thank you.
07-26-2020 11:15 PM
가장 좋은 방법은 acquisition software 2014 버전을 사용하는 것입니다.
07-27-2020 12:54 PM
Seems like you are using the NI-IMAQdx functions.
But it should be NI-IMAQ for camera link.
07-27-2020 07:52 PM
08-20-2020 02:40 AM - edited 08-20-2020 02:43 AM
I have succeeded in using "PCIe-1437".
However, it does not work on "PCIe-1433".
