06-12-2018 06:40 AM
Hi Everyone,
I want to use the Software trigger for basler cameras to take picture at a specific event.
the attached vi always give me a time out error and i don't understand the problem.
theoretically it should works, but maybe there is a parameter that i forget.
can anyone help me?
thanks
Solved! Go to Solution.
06-13-2018 06:28 PM
Hi mon3am,
What is the timeout error code? At which function does the timeout occur?
Do you seen the same behavior when testing with an example grab with software trigger? (https://forums.ni.com/t5/Example-Program-Drafts/IMAQdx-Grab-with-Software-Trigger/ta-p/3774563)
Angela L.
06-14-2018 03:34 AM
Hi Lagelin,
the error occur in the Snap Function.
thank you for your help
this VI is a solution.
