rn matching tools for fixturing being located around left and right holes. When it executes it measures various parameters. The values that I am getting are different then manual (pdf) indicates. Does that mean that the tool placement affects measurements?The left and right holes are found using the pattern maching tool. So, if the pattern match template are defined differently, then the center point for the match will differ also. This will then affect the measurement parameters.
My guess is that the images used for the PDF maybe slightly different, which will affect the results of the final measurements.
