Machine Vision
The Best Fingerprint Recognition Hardware?
Hello.
I am trying to create a LabView VI wihch will acquire and process a fingerprint image.
I have difficulty choosing the best suited hardware for the acquisition.
Throughout the research process, I found some infomation on the microsoft fingerprint reader.
However, I was wondering if the fingerprint acquisition would be possible with other kinds of hardware, such as webcam or different fingerprint reader with easier approach.
Thank you.
OC
(4,568 Views)
Accepted by topic author Mr OC
Dear OC,
A monochrome camera and monochromatic light source would be preferrable to a color web camera for assembling a fingerprint scanner.  The real trick is the optics that are used not the camera.  There is a document describing the various techniques used to image fingerprints located at http://ewkmmc.tuwien.ac.at/wkmp/fileadmin/user_upload/lehre/rp/ss2007/gr1_SFF.pdf.  Note: the platen of the FTIR scanners are often coated with silicone.
However, there are off the shelf fingerprint scanners that can be integrated with the NI products, for example http://www.solkey.com/Technology%20Vendors/Cross%20Match/Verifier/CMT_verifier_300_RS170.htm.  Here, the RS-170 video ouput from the scanner can be acquired via an NI PCI-1405 framegrabber.
-Robert Eastlund
Robert Eastlund
Graftek Imaging, Inc.
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
(4,564 Views)
Dear Mr.Eastlund,
     Thank you for the helpful advice, and for the references. I would be experimenting with a monochromatic system which consists of a usb webcam that has been set up for IR detection and makes use of LEDs to illuminate the area of interest (fingerprint). Hopefully this can get us a 'good enough' image that we can work with.
Thank you,
OC
(4,530 Views)
