Machine Vision
Strange IMAQ Error Message: "ni: A frame has been dropped and the acquisition has been canceled."
I am getting a strange error trying to use the NI PCIe-1427 with the MATLAB image acquisition toolbox configured with continuous acquisition.  After about 5 minutes of acquisition, I get the error below:
??? ni: A frame has been dropped and the acquisition has been canceled.
Does anyone have any clues as to why I am getting this error / where I can find out what causes it?  I need to acquire several hours worth of data and this error completely aborts my acquisition.
  --Y
(3,043 Views)
Hi Ysirotin,
What driver version do you have on your system? Can you post a screesnshot of the errors please.
Thanks and have a great day.
(3,027 Views)
Turns out that I found the problem.  I had a slow memory allocation in my MATLAB code and this delay allowed too many frames to be accumulated in memory.  I still do not know the source of the exact text of the error, but upon removing the slow memory allocation the error no longer occurs.  I believe that it may have resulted from a buffer overrun of some sort in the underlying driver.
Given that this no longer poses a problem for me, I will not pursue it further.
Thank you for your help!
(3,025 Views)
Hi, I have encountered the same problem.
What do you mean by "slow memory allowcation process"?
I have some 'getdata' functions there.
Could you please tell me how you get ride of that?
Thank you.
Yang
(2,763 Views)
Yang,
Unfortunately the issue appears to reside in MatLab and this thread is over 2 years old.  It may be worth contacting MathWorks for additional assistance or creating a new thread.
Isaac S.
(2,746 Views)
