05-02-2008 07:46 AM
05-03-2008 02:08 PM
I am only experienced with my Camera ( Basler / firewire type ) so this may not apply to other brands. With mine once I make changes in MAX I can save them so when I run IMAX the seeting is the default unless I change it but even if I do , it is not a permanent change like MAX . When in MAX if I change the ROI and dont save it it will ask me if I want to save the chnage when I exit MAX,
Maybe withe some cameras there is no way to change and save the changes.
Mario
05-05-2008 02:54 AM
I've seen the same error using IMAQdx in another post:
http://forums.ni.com/ni/board/message?board.id=200&message.id=16336&requireLogin=False
In this case the problem was related to the fact that properties should be setted before the Configure Grab vi. Anyway if you are using the example you mentioned it would be ok.
I've also noticed that your camera is declared compatible for use with NI-IMAQdx 3.1.1f0 or later (http://sine.ni.com/apps/utf8/nipc.product?pid=8702&asid=1102). Have you the possibility to upgrade your driver to a newer version?
Clara
05-05-2008 05:28 AM
06-19-2008 09:53 AM
Eblanco,
The lack of an ROI with the IMAQdx Snap VI pi**ed me off too!!! So, I made this simple little VI, "IMAQdxROI.vi". Just put it between the IMAQdx Open Camera.vi and IMAQdx Snap.vi or IMAQdx Grab.vi
John
