Machine Vision
Set center of the image to use as pattern in imaq OCR read text 3
I'm familiar with the vision assistant, and I know that you can set the coordinate of a pattern in the vision assistant, so that it looks for that image everytime in the image acquisition. Now, I am trying to do the same, but with the low level OCR (Imaq OCR read text 3). I want to assign the coordinates of the pattern that I have, to the ocr, so that it looks for the center of the image evreytime.
Can someone please tell me how to do this?
Thanks in advance!
(5,124 Views)
Hello Fernando;
I would recommend you use the Tools>>Create LabVIEW Code from the vision assistant and set up the parameters there and then pass them on to LabVIEW; otherwise you can try the following code
Hope this helps
Greetings
(5,095 Views)
