Machine Vision
Segment Image for OCR
Hello Sir,
I am working on character recognition using LabVIEW Vision and facing problem with image processing.
I need to segment characters in an image that have different backgrounds e.g dark(black) characters having bright(white) background and bright(white) characters with dark(black) background.
I am using background correction and this works well for dark characters having bright background but for bright characters with dark background i am facing difficulty.
I have attached a snapshot of the image.
Please suggest some solution.
Saukhyada
(3,817 Views)
Try running a histogram for the area you are interested in, and see if the average is lower for the light characters on a dark background. If it is then invert the section to allow you to use the same font file. Create the ROI from the edges of the dark section.
Mike
(3,810 Views)
