Machine Vision
Running Labview program, live video goes blank
Highlighted
Hi all, I am working with a code created to find the bullseye of an image using a template created from NI vision assistant. Upon starting the program, there is a live feed so that you can roughly line up the bullseye, then you click process button and it does a fine alignment.
The problem is, when the program starts I only have 30-60 seconds to line up the image otherwise the live image goes blank (white screen). I then have to restart the program to get it back. I can run the camera all day long in vision assistant so I don't think it's a driver/hardware issue. Thoughts on how to troubleshoot this?
Message 1 of 1
(246 Views)
