Machine Vision
Replacement for PCIe-1430?
Hello!
We have a customer getting a Specim camera, a Camera Link FX17. Unfortunately, the PCIe-1430 interface card is out of production, and the secondary market is pretty grim. Is there a recommended replacement or superceding product for the 1430?
Thanks!
(1,912 Views)
Is this camera requiring a dual base connection ?! Or do you need to interface 2 cameras ?
The only up to date option of cameralink grabbers is the 1437, which is cameralink full.
Sami
(1,859 Views)
Accepted by topic author Jack_608
I downloaded the user manual for FX17 camera. It is Camera Link Full (see attachment)
NI PCIe-1437 should work for you. You are going to need NI help to create the camera file.
If that is the correct camera I have downloaded then it should work fine.
Pixel per clock 80MHz
Number of tap 2
Bit per pixel 12/10/8
Line pause 18 clocks
Amit Shachaf
(1,851 Views)
