Machine Vision
Regular subVI is slower than Assistant-generated
I have LabView 2011 and Vision Module. I use Vision Assistant Express to generate the VI for image acquisition. If I convert the subVI to a regular VI (by double clicking and opening the front panel) the frame rate becomes lower in some cases almost twice). Why is this happening? Can I "back compile" the subVI to get it faster?
(3,201 Views)
Hello Dan Kostov
Thank you for bringing this issue to our attention.  I would very much like to reproduce to issue on our end.  Can you please describe your hardware setup to me?  As well, are you able to provide a sample VI as well as a sample project that illustrates the behaviour you are seeing?  Do you have a back-up copy of this VI where you achieve the full frame rate?  Please let me know!
Sincerely,
Greg S.
(3,196 Views)
